The Sony GTK-XB5 is a high powered home audio system with Bluetooth that was released in 2016. This audio system is available in black, red, and blue.
How to fix my power jack
I have tried to solder it back together but I am not sure if I have done it right can solder arc between it self as there is a small gap in the solder I did manage to turn it back on for a few seconds then it died then when I tried again there was a spark from the power jack
@andrewlang00 post some pictures of the jack and teh repair etc. with your question. Let's see if there was a solder bridge or similar that may have caused this. Adding images to an existing question
@oldturkey03 added photos also I am very aware my soldering job is terrible hopefully the pictures help tho
It was fixed to the board better when I first tested it but taking it in and out has loosened the solder
It looks like these are "cold" solder joints, which means the connection between the pad and the pins are not good, which would explain the sparking. Try to touch your soldering iron to the pin and the pad and the same time to heat up both and then apply solder so it covers the pin and the pad for a flawless connection.
Andrew Lang crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 174
