The Kenwood Chef A701A is a stand food mixer released by Kenwood.
crwdns2934591:047crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Overheating and smoking after 3 minutes
Have serviced mixer but still not good. Its gets very hot after 3 minutes, can hardly touch motor casing( motor is out of the mixer)
So far I have:
Replaced capacitor
Oiled both bearing felts.
Note there is no choke coil across resistor. Can this cause issue???
Cleaned commutator in drill with 400grit silicon carbide.
Cleaned govener contacts
Used dremel to remove small amount of mica between commutator bars, they were slightly protruding.
New brushes
Checked commutator coil resistance
Screamed at the machine several times, still no improvement.
Any help on any point appreciated
Love this machine
Regards
Eric
Update (03/05/2022)
This is the electrics
Eric
Update (03/05/2022)
I'm did not mark coil housing location when pulling apart. How can I before I have it in the correct alignment. I can see a punch mark is this meant to be used to align parts.
Update (03/05/2022)
Is this an alignment mark?
Update (03/06/2022)
168 and 169 trying to align
Update (03/06/2022)
Are these the scribble line and punch mark
Update (03/05/2022)
Jayeff,
Is this the scrib line and punch mark I need to align.
Regards,
Eric
Hi @phantomwalker ,
Here’s the service manual for the mixer. On p.8 it describes the re-assembly of the motor.
Hopefully this is of some help.
Jayeff, thank you.
I read it but can't see how to ensure the parts(Field Assembly and Drive End Frame Assembly 168 & 169) are aligned correctly.
This is the parts on red
@phantomwalker
Bit confused as you highlighted part #176 commutator end frame but mention part #169 drive end frame.
Was there no scribe mark on the commutator end frame and the field assembly so that they can be lined up?
Jayeff,
Thank you.
Where do I find the scribe mark. What does it look like?
Regards,
Eric
@phantomwalker
I don't know.
The manual only says to mark the end frames in relation to the "stack" (presumably the field assembly) before removing the motor.
The punch mark is there for some reason so it must be to line up with a mark on the end frame
Eric walker crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 791
