Earbud repair. Which adhesive to use for reassembly?
First time disassembling TWS earbuds for cleaning.
Before i started, this earbud would play at something like 40% volume.
Soaked my earbud in 99.7% Isopropyl for a day, which definitely got rid of all the wax and i can clearly hear that the volume is no longer a problem.
However the soak also weakened the adhesive inside, and i was finally able to disassemble the earbud.
It sounds like most of the bass is missing, but the rest of the sound profile is fine.
I attribute that to the now-missing adhesive.
I saw two types of adhesive inside, both feeling a bit like silicone adhesive to me.
One adhesive, used i most places, was black.
Second adhesive was white, and only used around the audio driver (presumably to provide a seal around the driver for the bass to work)
white adhesive can be seen on these photos here: https://fccid.io/2AUYFRMA2003/Internal-P...
Should i just use something like B6000 or B7000 adhesive which is used for phone screen repair?
Or is there a different adhesive i should be using?
I would say that b6000 or 7000 would work fine. Also, a little tip on applying it on small parts is get a needle an syringe and put some glue in the syringe so you have better control (just don’t inject yourself with glue)
vitmerc crwdns2934231:0crwdne2934231:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 119
crwdns2942667:0crwdne2942667:0 4,028
