Released in October of 2013, this wireless speaker system offered by Bose is easily identified by a product ID number of 355589-1200.
Teardown | breaking of ribbon cables
I accidentally broke the ribbon cable while cleaning the front mesh panel. Can someone guide me through repair or can suggest exact specification for Ribbon cable attached to the cover of the speaker. ??
Is there any up-down or front-back, in-out port sequence .??
For your reference please refer to image in step 8 of Bose SoundTouch 20 Buttons Replacement .
Will highly appreciate any valuable advice.
Regards,
Amit Katiyar
Hi Amit, I did the same thing. Are you still interested in getting some help with this problem? as I have learnt quite a bit about these ribbons as a result and successfully fixed LCD Display ribbon replacemnt.
Hi Amit , did you manage to get the replacement ribbon cables . If yes. kindly guide me . I am also facing the same issue . parveensalaria786@gmail.com . help will be appreciated .
@parveenksalaria Please keep discussions on site rather than using private email; that way everyone can benefit from your learning rather than just one person.
I did the same thing. I bought a new ribbon cable on Amazon you can also buy on AliExpress.
The cable description is:
uxcell B Type 0.5mm Pitch 12Pin AWM 80C 60V VW-1 Flexible Flat Cable FFC 200mm 10Pcs
Amazon link
https://a.co/d/0sQjQTs
Worked fine after all a ribbon cable is a ribbon cable. Good luck
Amit Katiyar crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 279
