Updated version of the 2016 Retina MacBook. Model A1534, EMC 3099. Now features faster Kaby Lake processors up to 1.4 GHz Core i7 with Turbo Boost up to 3.6 GHz and up to 50 percent faster SSD, and supports up to twice the memory.
Display error - lines on right side
Hey guys,
I plan on buying a used MacBook 2017 Retina. The picture shows, that it has a display error on the right hand side. As I will mainly use it with external displays attached, I don’t worry too much about it, but would like to know, if this is a common problem that is easily fixable or a bigger problem that needs a fix from apple?
Thank you all for your help,
Stefan
Hallo Leute,
ich habe vor mir ein gebrauchtes MacBook 2017 Retina zu kaufen. Auf den Bildern sieht man, dass es einen Displayfehler auf der rechten Seite hat. Da ich es hauptsächlich über externe Monitore betreiben werde, stört mich das nicht allzu sehr, aber ich würde gerne wissen, ob dies ein bekanntes, leicht zu behebendes Problem ist, oder aber etwas schwerwiegendes, was eine Reparatur von Apple benötigt.
Danke für eure Hilfe,
Stefan
The LCD panel in the lid got damaged. Likely along the edge so som e of the lines got severed. Sadly this will require a new display assembly MacBook 12" Retina (Early 2015-2017) Display Assembly iFixit only has the Rose Gold in stock. Here’s the guide to put it in Retina MacBook 2017 Display Assembly Replacement
Here’s a run down on the Apple P/N’s for the different units:
  • Gold - 661-02248
  • Space Grey - 661-02266
  • Rose Gold - 661-04852
  • Silver - 661-06786
crwdns2886500:0Replace a display compatible with the early 2015 to 2017 model A1534 12" Retina MacBook laptop. Includes the 2304 x 1440 pixel 12" LCD screen, aluminum case, 480p Facetime webcam camera.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$584.99
crwdns2944067:07crwdne2944067:0:
Sadly there are no replacements available for Germany. Any idea where I can source one that ships to Germany?
@narunac Which one? Silver, Space Grey, Gold or Rose Gold?
Sorry. Rose gold.
@narunac - Sorry it appears they are hard to come by right now. Give these folks a call TheBookYard Reference the part number.
true, i would recommend finding a donor laptop of the same kind MAKE SURE THE SELLER SAYS THE SCREEN WORKS, then transfer it to the laptop
crwdns2934275:02crwdne2934275:0
Stefan Teucher crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 184
