The Xiaomi Redmi Note 5 Pro is a mid-range smartphone by Xiaomi released February 2018. It has a 5.99" IPS LCD display, a 12 MP main camera, a 4000 mAh battery, a rear-mounted Fingerprint, and runs on a Snapdragon 636.
phone is stuck on loading screen for last 13 hours
My Redmi Note 5 pro is stuck on loading screen for last 13 hours.
last time my phone was not connecting to wifi so i rebooted it and from last 13 hours , it is stuck on loading screen.
I am facing exactly the same issue. What have you done to bring back phone to normal at this stage. Requesting for a quick response.
I just waited for my phone to discharge .
After battery was finished, I connected charger and started my phone simply.
Thanks for the response. One more worst thing in my case is my power button is not working.
how long it takes to the battery to discharge? I'm facing the same problem
Hi, I'm facing the same issue that you guys have been faced before.My phone i.e Redmi note 5 is stuck on reboot mode exactly same as the above mentioned image. Also, the power button is not working. Please help me on this .Please waiting for your response...
Hi,
Some things to try and resolve the problem:
i). Wipe the cache partition and then check if it starts OK
ii). Try starting the phone in safe mode and check that it starts OK.
If it does then a downloaded app may be the cause of the problem. The trick is to find out which one.
You will need to uninstall each downloaded app, one by one and then test the phone in normal mode to see if it now works OK. When it does, the last downloaded app that was uninstalled was the culprit.
A downloaded app is one that you downloaded and installed on the phone and was not pre-installed on the phone.
Pranjal Nimbodiya crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 42
crwdns2942667:0crwdne2942667:0 3,240
