Model A1502 / 2.4, 2.6, or 2.8 GHz dual-core Intel processor / Released October 2013
crwdns2934591:0552crwdne2934591:0 crwdns2934593:0crwdne2934593:0
MacBook Pro late 2013 wifi no hardware installed
Hello, I got a late 2013 MacBook pro, A1502 emc2678, that works almost perfect but it says WIFI: no hardware installed. I looked inside and saw that the coax connector was torn off on the airport card so I replaced that but even after replacing the card it stills has that same error. I don’t know if the cables are damaged as well or if the logic board is.
Here is a link to the images of the mac: https://imgur.com/a/fccIbiV
crwdns2942205:01crwdne2942205:0:
Can you post some pics so we can see the damage Adding images to an existing question
I do see a bit of tarnish on the contacts that should be cleaned. Find a fresh (still soft) pink pencil eraser. Carefully wipe the contacts in the direction of the pins, then wipe down the surface with a damp lintless cloth with 90% or better isopropyl alcohol (reagent quality) see if they helps. otherwise I think you need a new AirPort board.
I don’t see anything wrong with the cables did the connector pop off? If it did you might have a short or not a good connection.
MacBook Pro 13" and 15" Retina (Late 2013-Mid 2014) Airport/Bluetooth Board and the guide MacBook Pro 13" Retina Display Late 2013 AirPort Board Replacement
crwdns2886500:0MacBook Pro 13" and 15" Retina (Late 2013-Mid 2014) Airport/Bluetooth Boardcrwdne2886500:0
crwdns2934075:0crwdne2934075:0
$49.99
Jake Briggs crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 120
