Released 2016, this Sharper Image stunt drone is rechargeable and has a 150-foot flying range. It is black with 4 propellers. It has a 2.4GHz transmitter. It requires no FAA registration and includes charging cable and (4)replacement blades. It has removable blade guards.
Why does my device not lift off
All the blades spin but it will not lift off the ground
Hi,
Have you checked that the propellers are fitted correctly and are in their correct quadrants?
Each blade has a number written on it. Match the blades with the corresponding number on the drone. If incorrect carefully unscrew the propeller and reposition it in the correct place.
It could also be a expanding/defective battery. I’ve had a similar problem where the drone’s battery was expanding and could not supply enough power to lift off. I would find the voltage of that battery under normal circumstances and test the battery’s output. Hope this helps!
Paul Eyrich crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,800
