The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
No sound and battery not charging with loud fan noise
I was in the middle of watching a show and my sound stopped working all of sudden. I tried all the solutions I could find online and none of them worked. I also realized the battery icon on the taskbar disappeared and my Macbook is no long charging along with a loud fan noise
Update (12/26/2021)
Thanks for your response. After a day of leaving my laptop off the battery seems to be charging again and the fan noise is also gone but the sound still hasn’t come back would this still be an issue with either I/O Board or I/O Cable?
I have attached a snapshot of my battery information from coconut battery
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
Getting a view of the battery via Coconut will help in discovering if the I/O board is the issue or if the I/O cable is.
The loss of sound revolves around the I/O board DAC logic (Cirrus chip) MacBook Air 13" (Mid 2013-2017) I/O Board and the headphone jack which has some switches within it
Hopefully its only the cable MacBook Air 13" (Mid 2013-2017) I/O Board Cable
Review this guide to replace either MacBook Air 13" Early 2015 I/O Board Replacement
Update (12/26/2021)
Well thats a bit of a surprise! Your battery is also at the end of its life. You’ve squeezed out over 1,433 cycles when the battery was only expected to last 1,000. Determine battery cycle count for Mac notebooks while its also a bit on the old side as well being over six years. So its clearly time for a new battery MacBook Air 13" (Late 2010-2017) Battery and here’s the guide MacBook Air 13" Early 2015 Battery Replacement
So now it’s a matter of replacing both the battery and the I/O board.
crwdns2886500:0Replace an I/O Board Cable compatible with the Mid 2013 to 2017 13" MacBook Air laptop. Fix the connection between the I/O Board and the Logic Board.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$14.99
crwdns2886500:0Replace a used I/O board compatible with the Mid 2013 to 2017 MacBook Air 13" laptop. Fix problems with charging, audio, and data connections. Includes the MagSafe 2 power, USB, and audio ports.crwdne2886500:0
$52.99
crwdns2886500:0An aftermarket replacement battery compatible with a MacBook Air 13" laptop.crwdne2886500:0
$69.99
crwdns2886500:0MacBook Air 13" Early 2015 I/O Boardcrwdne2886500:0
crwdns2930805:0crwdne2930805:0
crwdns2934079:0crwdne2934079:0
crwdns2937801:0crwdne2937801:0
35 minutes
crwdns2886500:0MacBook Air 13" Early 2015 Batterycrwdne2886500:0
15 minutes
Parvinder crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 268
