In June 2017 Apple updated its 13" MacBook Air with a newer Broadwell Intel Core i5 processor, resulting in slightly increased performance and battery life.
LCD Only Replacement Guide Request
Goodmorning to everyone!
I have an Early 2017 13” MacBook Air and my LCD is damaged (black corner).
Since replacing the entire LCD and shell assembly is quite expensive, is it possible to replace the LCD only? (It costs a third!)
And if so, is there a guide to do so? I only found some guides relative to the older or 11” model… Are they the same inside?
Thanks in advance for helping! (And sorry for my poor English!)
Stay healty!
While you are right replacing the LCD panel on its own would be cheaper. The issue is finding the correct LCD panel as well as the needed work is not as simple as it appears!
Behind the panel is a collection of plastic sheets which manage the backlight pathway so the screen gets an even wash of light. Often people damage these sheets or get them dirty which causes image illumination issues.
Unless you have the correct panel, have a spotless work space and can manage the dust levels in the air. It would be just smarter to replace the full assembly.
Sorry we don’t offer panel replacement guides as its so tricky to get right.
HOW does the backlight flex cable connect back to the thin connection board?
It seems to go in but pops out very easily as there is no latch for it..... guys on YT do it but their fingers are in the way or it moves to quickly and it appears a little different, mine is a orange color MBA early 2017.... I am stuck at this stage and it is driving me crazy.... @danj @oldturkey03 save me!
@livfe - Are you asking about the display cable as seen in Step 19 in this guide MacBook Air 13" Early 2017 Display Assembly Replacement or within the display assembly? Which is similar connecting to the T-CON board.
@danj I made another post which you have answered.
vincy722 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 301
