iPhone fell on the asphalt, black screen and vertical lines
Hi, about a week ago the iPhone fell on the asphalt and when I took it back, it presented the black screen with vertical lines, initially not even the sounds worked. Then in the following days, the audio started to work again, it is emitted very well both if you unlock the phone and if you also open some music files, however the screen always remains with this black background and these vertical lines. Everything works, even the touch I used to unlock the iOS system (the unlock sound is heard in the video), the screen has no crack. It happened with another iPhone 4S, it fell to the ground on the floor, a crack also formed, but it never happened that the screen with black background and vertical lines appeared. With this iPhone, however, it is different, the screen does not have this different state, but the background always remains, even if more than a week has passed, with a black background and these vertical lines that I will now show you in the video: https://www.youtube.com/watch?v=UF23Mwro...
You will need to replace your screen(screen replacement available here).
crwdns2886500:0Replace a screen compatible with iPhone 4S. Includes all of the small parts pre-installed in the assembly, saving time and increasing the quality of your repair. 3.5 inch IPS LCD (640 x 960 pixel) Display.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
iPhone 4S Screen
$34.99
Why iPhone display got that situation with black screen and vertical lines? If you notice, it has not cracks, so, how is possible this?
@pikachu95 Sometimes the glass is stronger than the LCD behind it, causing the LCD to show lines when the glass is unbroken.
Patrizio Masini crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 108
