Model A2159, EMC 3301. A refresh of the entry-level 13" MacBook Pro. Available in Silver and Space Gray. Released July 2019.
crwdns2934591:0112crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Display becomes black after a minute or more
MBP model is A2159. I am able to view the login screen properly upon opening the lid. I can type in the password and can reach the home screen.
After some time (the shortest being 5 seconds and the longest being 1 minute) the screen goes black with blueish vertical lines as shown below.
During this time the screen stays undisturbed. Every time I open the lid the display shows up correctly and then goes black. What can be the issue here?
  1. Can it be a display (LCD) issue?
  2. Can it be a problem with the flex cables?
The screen that I am getting is similar to the issue posted here: Black screen with blue vertical lines on MacBook Pro
Appreciate if someone could help me on this.
Your issue is not the flex cables, what you are seeing is the screen resolution change from the lower clocking to the higher clocking. What happens is the T-CON logic which is part of the display assembly can’t comply to the logic boards change so you get this image.
Basically the display assembly has failed ;-{
To prove it connect an external display it should work with no issues while your internal ends up being a black screen.
MacBook Pro 13" Retina (Mid 2018-Mid 2019) Display Assembly and here’s the guide to put it in MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement
crwdns2886500:0MacBook Pro 13" Retina (Mid 2018-Mid 2019) Display Assemblycrwdne2886500:0
crwdns2934075:0crwdne2934075:0
$479.99
Harikrishnan A S crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 183
