Liquid damage, a lot of stuff broken, still turns on.
Okay, so back in May, I spilled water on my MacBook Air (it was water from my Reverse Osmosis system if that helps).
It did turn off, but I was so worried that it wouldn’t turn on again that I tried turning it on, and it did actually power on. However, the display started flickering and eventually went so dim that you needed a flashlight pointed at the Apple logo on the back to see it.
The keyboard and trackpad did work for a little bit after the spill, but then they both stopped working (haven’t tried in Linux or Windows yet, however), and the KB backlight works. IDK if this is useful or not, but the caps lock light stays on all the time.
Another thing that happened was that the MagSafe light would stay orange, even without the battery, and with the battery in, it wouldn’t actually charge and the OS said that the battery needed to be replaced. Based on the MagSafe light, and the fact that the battery percentage still goes down sometimes, I can almost confirm that it’s the logic board.
Do these all sound like logic-board-related problems? Thanks!
EDIT: I added the coconut battery image, it looks like the battery is still in good condition, it might just be that the SMC is all messed up.
Sadly the systems charging logic on the main logic board and/or battery has failed. Time to visit an independent show who can fix your logic board.
crwdns2934271:0crwdnd2934271:0 Dan crwdne2934271:0
