Released September 20, Apple's largest and most expensive 2019 smartphone features a 6.5" OLED display, a triple-lens camera system, and greatly improved battery life. Successor to the iPhone XS Max.
CPB Heating Mat for iPhone 11 pro max screen removal
I’ve got a CPB mat and it worked like a charm on several iPad projects.
So i’m having bit of an issue opening the iPhone 11 pro max using the iopener, no luck.
The CPB mat has phone mode so what is the recommended temperature (in Celsius) should I use and how long should i set it on the mat?
For iPhones, I always uses 80 C, but I work with people who use 99. It really depends on how long you want to leave the phone on the mat. If you use a lower temperature, you can leave it on for longer without damaging any internal components with the heat, but higher temperatures give you more time to work with after you take it off the mat. It’s up to personal preference, but 80 C is close to the minimum. You may be able to get away with 70, but you’d risk damaging the internals by having to leave it on the heat for so long.
Thanks for your response. I've used 60c on the mat, left it on for a few moments then the mat shut down by itself. The screen did opened.
Gabriel Rodriguez crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,134
