Repair information for non-Apple computer keyboards.
Steelseries Apex 5 button problem
Hey, so i had my apex 5 for not so long and three keys (C, V and ,) has to be pressed really hard to make an input. Any solutions or ways to fix? Much love, some help would be appreciated! Also, after i press the button and hold it for some time it functions normally for some time and after that it goes back until i do the same thing
usually with those types of switches when they go they go, you might be able to order some replacement ones and re solder it to the board. but odds are this is not going to better.
i had a logitec keyboard that allowed you to solder on new keys so you might be able to do that with this!
do you have a warranty anymore? it might be worth looking into that also
i hope this helps!
I am not sure how I would solder them, but this keyboard is mech membrane, it's membrane keyboard with mechanical keyboard feel, is there any way that one can fix membrane with this kind of problem? Also I have seen some videos of people fixing membrane keyboards, but those were not working at all
gotcha, so if thats the case you might be able to seperate the membrain and clean it out that way it meakes a better connection. also it just might be worn out. only way to know would be to open it up.
i would suggest just open it and then repost some pictures maybe
Do not try to pull the membrane apart. It will destroy all the other keys. This keyboard isn't made to be fixed. Once the keys stop working, you either put up with them not working or you get a new one. There is no way to fix them, and there's no point in messaging Steelseries support, they're the most useless people on the planet. They're stuck-up and snobby, slow, and they won't give you any help to fix your own stuff, nor will they even sell you replacement parts.
Honestly, don't even buy Steelseries products anymore. I made that mistake a couple years ago and I've since changed everything to better companies like Logitech and Razer and I haven't looked back. You can pick up a keyboard like the Logitech G413 SE which is full mechanical but only has white LED's for the same price as the Apex 5. It feels better, works better, lasts longer, is made better, and comes with better support. If you're willing to throw all those things away just for looks, then Steelseries is okay. Otherwise steer clear.
Has anyone tried to remove the membrane? I've had luck with getting a non-responsive volume key working again on a Media Centre Remote in the past by gluing some conductive tape under the button to replace the perished conductive coating on the bottom of the membrane.
This could totally be a viable option if the membrane's easily removable?
Gytautas Kačinskas crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 65
crwdns2942667:0crwdne2942667:0 2,409
