No display 3 beep error
- My 1155 socket motherboard has no display has 3 beep error. I replaced ram and cpu and still no display. What could be the problem and how can I fix it? (1155 Intel motherboard I3 cpu, ddr3)
Hi Albert,
We can't accurately help you unless you tell us what make and model your motherboard is. You have only told us the socket name/number. Look around the board - usually in white ink also look for "Revision" or "Rev" or "R" with a number following.
But having said that if it is an Intel board:
3 beeps On-off (1.0 second each) three times, then 2.5-second pause (off). The pattern repeats until the computer is powered off.
Cause :Memory error
Solution:
Older Board:
1 long beep followed by 2 short beeps Video configuration failure (a faulty video card or no card installed), or an external ROM module does not properly checksum to zero.
3 beeps First 64K memory failure.
Intel Board dh61ww
A 3 beep error code for your motherboard is a memory problem
If you have two memory modules installed try starting the desktop with only one inserted.
If no good try the other one.
Here's the user manual (see p.37 →) to show how to remove, insert the modules.
Try doing this in memory slot B as well if it doesn't work when each module has been tried in slot A, in case it is a memory slot problem and not a memory module problem.
If I insert it in memory slot B it doesn't beep anymore but still no display and also no beep when I have 2 inserted
As there are no longer any beeps heard when 2 ram modules are inserted, I'm just verifying that now it boots up but with no display is this correct?
If so re-seating the ram modules seems to have fixed the 3 beep error code on startup.
Have you checked if the monitor is working OK by seeing if the monitor's menu screen works etc.? Usually most monitors allow some sort of adjustment using the controls on the monitor itself and this is displayed on the screen. have you tried a different known working monitor, you didn't say?
If the monitor is OK then is the monitor connected to the motherboard's vga port or is the monitor plugged into a GPU card inserted into a PCIe slot on the motherboard?
If a GPU card, remove the card and plug the monitor into the motherboard's vga port (if you have the appropriate cable etc) to see if there is a display using the integrated video from the i3 CPU.
If there is then there may be a problem with the GPU card
I have tested on 4 different monitors but stil no display and tested with and without gpu. When the display was working I bought a gpu to play better games but when I inserted it went on but no display but when I tried on motherboard vga port there wasn't display either and it is when the beep error started.
crwdns2947821:0crwdne2947821:0
Clean processer and ram slots out the cell replug
A 3-beep error code on your 1155 socket motherboard usually indicates a memory issue. Since you've already replaced the RAM and CPU, the problem might be related to the following:
# Graphics Issue: Check your graphics card or integrated graphics. Ensure it's properly seated and connected to the display.
# Power Supply: Verify that the power supply is adequate and all connectors are secure.
# BIOS/CMOS Reset: Try resetting BIOS settings by removing the CMOS battery or using the reset jumper.
If none of these solutions work, consider seeking professional help or replacing the motherboard.
What does 3 long and 3 short beeps mean?
It means there is any problem with your Pc RAM STICK.
To fix it remove it our clean and reinstall it simple solution.
In my case I have it didn't work and still facing the issue so I insert in the slot no.2 damm problem solved.
https://howtofixgadgets.com/how-to-fix-3...
I will suggest you to read this, this will fix you issue 101 % this will give you a detailed info.
Abhilash thanks bro after 24 hour of search just solve this problem.
crwdns2936751:024crwdne2936751:0 23
crwdns2936753:07crwdne2936753:0 142
crwdns2936753:030crwdne2936753:0 587
crwdns2942667:0crwdne2942667:0 71,514
crwdns2944067:08crwdne2944067:0
from which manufacturer is that motherboard? You can check the manufacturer's guide on beep error codes.
Usually, a 3-beep error indicates a system memory error. If it is, please check your ram module if it is seated properly.
crwdns2934271:0crwdnd2934271:0 Jared Salazar crwdne2934271:0
Reseat/replace memory
crwdns2934271:0crwdnd2934271:0 Ben Capehart crwdne2934271:0
My computer beeps three times but rams is perfect i dont know why beep three times can u help me to solve this problem
crwdns2934271:0crwdnd2934271:0 VIPEX YT crwdne2934271:0
@VIPEX YT
What is the make and model number of the motherboard?
crwdns2934271:0crwdnd2934271:0 jayeff crwdne2934271:0
crwdns2934271:0crwdnd2934271:0 Jess Rubio crwdne2934271:0
