Released in July 2018, the 15" MacBook Pro, model A1990, features a 15.4 inch LED-Backlight display with True Tone technology, TouchID, and up to 6 Core i9 Processor.
Random Shutdown on BATTERY ONLY
I'm having problem on my MacBook pro 2018 15” with Big Sur 11.6 , my MacBook randomly shut down running on battery and after 1min i press power it’s working again normal .
battery in coconut status good but in system report is service recommended
I have completed the SMC and PRAM reset. and not working with me , What else can i do … any suggest?
Did you try running the onboard diagnostics yet? Restart your system and press the D key to enter, did you get any errors?
Reference: Mac startup key combinations
thanks Dan for reply ,
yes i did it before and get this ADP000- No issues found
Then that tells me your system is likely overheating!
So it might be a simple case of cleaning the dust out of the fan blades and heat sink fins. I would also carefully dust off the logic board as well. In its self this likely won’t fix your issue but it should lengthen your systems run time as your logic board has a failing component or solder joint which will need to be investigated,
This should prove the boards temp is the issue or not. Let us know what you discover!
hany crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 118
