Can I use surface book without the screen battery?
i have a surface book 1st get with a Swollen Battery(behind the screen).
does anyone know if after removing the battery from behind the screen, will i be able to use the surface book without a battery installed?
i plan on using it as a desktop only henceforth, though is it possible?
Old question but others may look at it for future reference. Maher Haddad yes it will run without the battery. You just have to keep it plugged in. This of course defeats the purpose of a laptop/tablet.
Sorry you’ll need to replace it! Here’s the needed part Surface Book 1/2 13.5" Tablet Battery and the guide to put it in Microsoft Surface Book Battery Replacement
crwdns2886500:0Replace a 2387 mAh battery in the display or tablet section of a 1st or 2nd generation 13.5" Microsoft Surface Book. Part #DAK822470K. 18.0 Watt Hours (Wh). 7.5 Volts (V).crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$39.99
Unfortunately, you can't, I just tried this and the system basically boot loops... You can use it with just the keyboard battery though (if you keep the tablet battery BMS installed, that is).
If you remove both batteries (keyboard and tablet), same result: boot loop.
Maher Haddad crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 636
