Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
crwdns2934591:0376crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Info On Dust Cover For CD/DVD (Rubber or Felt Ribbon)?
I have a late 2008 or early 2009 MacBook Pro UniBody, Model A1286 which the dust shield pulled out and broke when I removed the CD Disk. My question is, when I look for the part, it's not listed. Does it come with the Left Speaker assembly or with a replacement CD/DVD drive, or can you buy the gray rubber band looking part separately, and if so, what is the part number. Thanks in advance
Does that mean I have to buy the complete UniBody, or can I get just the part I need, if so, What is a good part number. Thanks in advance
I don't know if there is a part number. Contact iFixit and reference this question. They may be able to help you.
http://www.ifixit.com/Info/contact
as far as I know its not a separate piece. you would need to replace the unibody
I edited your MBP description to match Apple's and got the right tear down and parts list. I'm not sure I know what the gray rubber band part is but see if you can spot it on the drive.
Here's how to install the optical drive: MacBook Pro 15" Unibody Late 2008 and Early 2009 Optical Drive Replacement
Here's how to repair the left speaker:
MacBook Pro 15" Unibody Late 2008 and Early 2009 Left Speaker Replacement
crwdns2942205:01crwdne2942205:0:
I found that info a while back. On the right side of the MBP, there is a slot where you stick in the CD. Inside that slot, there is a shield or cover that is made out of felt or rubber or something soft that I guess keeps dust out. When I ejected a cd a few weeks ago, the shield came out or stretched out and broke when the cd came out. I need to replace this part. What I need to know is, does this part come separately, or does it come with a new CD drive or the Speaker housing. I have looked at both parts on line, and I don't see it on either part and I can't find it listed separately. I am trying to find out before I tear down the MBP. I hope this clears up what I need. Thanks in advance.
The "Dust cover" is part of the case - for a unibody model, its part of the unibody enclosure.
I am looking for the same part, with out the rubber cover the dvd when ejected shoots out into the air.
[deleted] crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 4,449
