Sixth generation of the iPad, released in March 2018. Available in Wi-Fi and LTE with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
Missing Pads Charge Port
Hello,
I am missing charge port pads for pins 5, 12, 14, and 20 for an iPad 6th Generation WIFI. Can some help me identify any test points on board where I can jump these to the connector?
Thanks in advance!
crwdns2944067:05crwdne2944067:0
you need to mark the pads in the photo or picture - the numbers of pins and lines are not marked on any of the available diagrams (let's at least set the starting point and the direction of counting - so as not to make a stupid mistake). At the same time, I confirm - such a check is possible
I am missing the ones highlighted in light blue.
wait...
mmejia04 post a picture of your actual board as well. That way we can actually see the placement of the components and follow the traces as per schematic....
I posted a new picture, the pads inside the red boxes are the ones needed. The other pads are either connected to ground or have a second connection to the same point.
hello there,
here you've got
Thanks for all your help!
I am sorry, I missed to add another pad, the one right next to the purple one.
no problem, pict upgraded
hi can i you help me to pin point positive and negative pin to charge the ipad 6th gen beacuse the pin was destroy im trying put jumper on it
Hi @bryanlutuaco ,
yes, of course. unfortunately, it is difficult to post anything in the comments section :-) So start a new thread and throw a link (preferably by email - you will find it in the "about me" tab) so as not to miss it in the thicket of other messages.
mmejia04 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,039
