Fix Mbr showing error
As above question my problem is same
But it is showing this error
Type ''BOOTREC /FIXMBR ''and hit <Enter>.
This command will attempt to fix any corruption issues with the master boot record. If all goes well, you should see The operation completed successfully.
Next, type BOOTREC /FIXBOOT then hit <Enter>.
This command will attempt to write a new boot sector on the hard disk if Windows detects damage. Usually, this happens in cases where an older version of Windows was installed, or a non-compatible operating system such as Linux was installed.
If you are seeing an error such as Boot Manager is Missing, then the BOOTREC /RebuildBcd command might be able to fix it. This operation can also restore boot entries for older versions of Windows if you have a dual boot configuration.
If BOOTREC /RebuildBcd does not work, then Microsoft recommends you back up your BCD (Boot Configuration Data) store, then run the BOOTREC /RebuildBcd command again. Here is how you do it. Type each command then hit <Enter>:
· bcdedit /export C:\BCD_Backup
· c:
· cd boot
· attrib bcd -s -h -r
· ren c:\boot\bcd bcd.old
· bootrec /RebuildBcd
You sure it's not
fdisk /fixmbr
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 266
Which version of Windows are you using?
Which error message did you get that prompted you to try and fix?
crwdns2934271:0crwdnd2934271:0 mike crwdne2934271:0
