Repair guides and user manuals for the Lenovo IdeaPad 330-14AST. The Lenovo IdeaPad 330-14AST is a laptop designed for casual use.
Fix Mbr showing error
As above question my problem is same
But it is showing this error
Which version of Windows are you using?
Which error message did you get that prompted you to try and fix?
Type ''BOOTREC /FIXMBR ''and hit <Enter>.
This command will attempt to fix any corruption issues with the master boot record. If all goes well, you should see The operation completed successfully.
Next, type BOOTREC /FIXBOOT then hit <Enter>.
This command will attempt to write a new boot sector on the hard disk if Windows detects damage. Usually, this happens in cases where an older version of Windows was installed, or a non-compatible operating system such as Linux was installed.
If you are seeing an error such as Boot Manager is Missing, then the BOOTREC /RebuildBcd command might be able to fix it. This operation can also restore boot entries for older versions of Windows if you have a dual boot configuration.
If BOOTREC /RebuildBcd does not work, then Microsoft recommends you back up your BCD (Boot Configuration Data) store, then run the BOOTREC /RebuildBcd command again. Here is how you do it. Type each command then hit <Enter>:
·                     bcdedit /export C:\BCD_Backup
·                     c:
·                     cd boot
·                     attrib bcd -s -h -r
·                     ren c:\boot\bcd bcd.old
·                     bootrec /RebuildBcd
You sure it's not
fdisk /fixmbr
Satyam Singh crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 547
