Well what I can tell you is your battery is just fine! And your systems charging logic is also working properly.
That aims us to either a OS level issue or a SSD issue.
I would start off creating an external bootable drive with the same version of macOS your system is currently running. That way you can boot up under it to see if your issues go away. Then slowly transfer each app over to see if one is your issue. Otherwise using your external drive as the boot drive run Disk Utility to check and fix any errors you have on your internal drive.
That leads me to what is your current internal SSD? Are you still using the original Apple SSD or did you upgrade it? Also how full is your drive (your SSD’s size and the amount of data it currently has).
Maybe your issue is a bad drive or one thats running too tight of free space.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
0
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
crwdns2934271:0crwdnd2934271:0 Dan crwdne2934271:0
Hi Dan, thanks so much for replying. I have attached the screenshot as requested.
crwdns2934271:0crwdnd2934271:0 James Strogger crwdne2934271:0
