can’t plug any charger into port.
My iPad Pro fell off the bed with the charger plugged in, so removed it, it was bent and now can’t plug any charger into port. Must have done something to the inside. And how much would it cost to repair, rough estimate?
It depends on the model. In some models the port is soldered to the main logic board and in others it's on a separate daughter board. Call around your local repair shops to get some estimates. If it is soldered to the board, I recommend you contact either iPad Rehab, STS Telecom, Rossmann Repair, or VCC Board Repair and they should be able to give you an estimate.
Donna Ornduff crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 91
