Where do I find parts to fix VR2
I am fairly new to ds repair so I can sometimes do more damage than fix and I broke off the vr2 screw thing. (picture below)
Professor Smartie that “screw thing’ is actually a Variable Resistor. Some people also call the (Trim) Pot for Trimmer Potentiometer. Your DS Lite should have two of those. VR1 is for the upper display and VR2 for the lower display with touch. Measured looks like a 50K pot. Set your pot that the resistance is around 15K between point 1 and 2. You can still make adjustments if your find scan lines on your display etc.To high and your screen may just fail or your power circuit, so be careful . BTW, you do realize that this needs to be soldered in place. Now for as to where to get it, I’d start at places like this
Good day, I have a D's lite for sale in good working order if you are interested. Including 4 games, 2 chargers, case and stylus.
Hi! It's been a while since you've posted this, but I have the same problem.
I can find this part instead https://www.digikey.ca/en/products/detai...
It looks like it's shaped different but the overall dimensions are the same.
Do you think I can try using that one?
@jordigh looks doable. Only difference I see is the one you selected has 0.10W whereas the original used a 0.15W but should be negligible. Just make sure you keep it around 15K between point 1 and 2.
Thank you so much! Btw, I have been reading many of your other replies on DS Lite repair and I want to personally thank you for the help you've been providing over the years. We see you!
@jordigh all the best to you and your repair. Let us know how it works out!
crwdns2936753:030crwdne2936753:0 60
crwdns2942667:0crwdne2942667:0 3,176
