Released September 21, 2018. Models: A1921, A2101, A2102, and A2104 / Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray (Pronounced "iPhone 10 S Max.")
What’s up with my iPhone battery?
I’ve bought an iPhone XS Max battery (Not from ifixit), after installing it and using it for around 7 hours, I’ve found that when connected to the charger, it will charge but the percentage will not go up.
Weird right? I immediately contacted the seller to replace it and the replacement (A different brand this time) does the same thing.
Now I’m thinking what to do. Should I buy an ifixit battery or would it do the same thing again?
If two different batteries are not charging and you have tried another cable it could be a faulty dock connector assembly. You will need to rule this out.
If you have tried the above suggestions and the battery is still not charging it will be a logic board issue and will need to be looked at by a reputable repairer.
Ty Senpai crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 87
