Teardown information for the Nespresso CitiZ coffee machine. They are available from different brands, e.g. Krups, DeLonghi.
crwdns2934591:08crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Nespresso CitiZ coffee machine, some water is leaking into collection
I have a Nespresso CitiZ coffee machine and some water is leaking into the collection tray without passing through the coffee pod. I assume that an internal seal has worn out. How easy is to renew the seal and from where can it be sourced?
Hi @kaput43,
Here’s the Ifixit Nespresso CitiZ Teardown guide that should be of some help.
Here’s a link to the parts for the machine.
Once you have found the problem search online Nespresso (insert part number) to get results for suppliers that suit you.
Looking at the Exploded View1 pdf document at the top of the parts list it appears as though the machine is a rebadged De Longhi machine. This corresponds with the part numbers when I searched for a few parts by using the above method, as the results were also for De Longhi machines.
crwdns2942205:01crwdne2942205:0:
Those parts prices are ridiculously high! I'll probably just buy a new unit.
Probably the brewing unit needs to be replaced. Here is the guide from iFixit (in German). The spare part costs about 25€.
Firstly, kudos to you for taking the initiative to fix the leakage issue yourself. It's always great to try troubleshooting before seeking professional help. However, I couldn't find the specific guide you mentioned. Nevertheless, here are some general steps you can follow to address this problem:
  1. Double-check the water tank.
  2. Inspect the seals.
  3. Descaling the machine.
  4. Check the drip tray.
  5. Run a water-only cycle.
Graeme crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 76
crwdns2936753:030crwdne2936753:0 329
crwdns2942667:0crwdne2942667:0 6,009
