2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
crwdns2934591:0274crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Issue with brand new battery install
I purchased the battery install kit, and had no problems as far as getting it installed. Followed the steps afterwards to properly charge it the first time around. I noticed at around 65% charge left, the battery level jumped down to 8% out of nowhere. Not really sure what happened but now I’m worried the battery isn’t any good.
Has anyone run into this problem before? The battery info says the battery is in good health so, not really sure what to think. Here is more info on the battery though:
Battery Information:
Model Information:
  •   Serial Number: D8610************
  •   Manufacturer: ifixit
  •   Device Name: bq20z451
  •   Pack Lot Code: 0
  •   PCB Lot Code: 0
  •   Firmware Version: 2
  •   Hardware Revision: 00aa
  •   Cell Revision: 2
  •   Charge Information:
  •   Charge Remaining (mAh): 1933
  •   Fully Charged: No
  •   Charging: Yes
  •   Full Charge Capacity (mAh): 8890
  Health Information:
  •   Cycle Count: 2
  •   Condition: Normal
  •   Battery Installed: Yes
  •   Amperage (mA): 4104
  •   Voltage (mV): 11678
I added the screenshot of coconut battery as well. I just realized this seems to be a common issue with Ifixit batteries, for whatever reason.
crwdns2942205:01crwdne2942205:0
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
I don’t see any issues with this battery currently.
Are you sure you saw something which might be just normal as your system was active on something without your knowing so it ran the battery down.
I would take another snapshot when you see it again.
crwdns2942205:01crwdne2942205:0:
It looks completely fine, but it isn't. I just followed the steps like it said after you replace the battery. im going to try the 'Reset the NVRAM/PRAM and Reset the SMC' in hopes that makes it better.
I read so many good things about Ifixit batteries but, never expected it to have issues with this. At this point, I'll just accept it cause I don't feel like requesting a replacement from Ifixit and ripping the battery out again.
Woolfy crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 104
