Nearly new OEM battery dead (not the first time)
I have a Mid-2012 15” MBP with a very gently used battery - CoconutBattery says only nine charge cycles, yet the battery’s shot and needs to be replaced.
This happened to me with a black MacBook (non-unibody) battery awhile ago, too. Is there any way to force reset these batteries?
Unfortunately not as from what I understand they have a built in chip that saves data such as Cycles & capacity, furthermore just to be on the safe side it is not recommended to use a faulty battery as it can quite easily cause other issues that will likely require board level work to repair which can get quite expensive.
As Livfe said in an earlier comment, I wouldn't recommend using a "shot battery." However, you could attempt resetting the SMC on both this laptop and your mac: https://support.apple.com/en-gb/102605 as it might help.
Claire crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 95
