Why am I not seeing SSD in Disk Utility after installing?
HI, I found a video on youtube about installing an SSD using an adapter that looked quite easy to install. But after doing this, I am not seeing the SSD in Disk Utility. He was installing it in the same Mac mini. I purchased this adapter. and purchased this SSD. I started up in recovery mode, and opened up DU, but only see the HD. Shouldn’t I see it at this point, in order to format it? I’m sure it snapped in fully, though I can recheck it again if that might be the issue. The SSD fit nicely inside the adapter. Did I purchase items NOT compatible?
Any help would be appreciated, Thanks!
Rebecca
edit:
Oddly, the links didn’t show. These are what I purchased:
Adapter: Sintech M.2 NGFF NVMe SSD Card for Upgrade Mac Mini Late 2014 Year A1347 MEG Series
SSD: Western Digital 1TB WD Blue SN550 NVMe Internal SSD - Gen3 x4 PCIe 8Gb/s, M.2 2280, 3D NAND, Up to 2,400 MB/s - WDS100T2B0C
What is the macOS you are system is using?
That was it! I just finished updating to Big Sur and NOW I see it. Was just about to delete this question and saw your reply. Thank you!
Hello, did you install the Mac OS and After formatted?
Did you replace the main drive?
rebknell crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 322
