Internal Speakers Not Working
I have an early 2015 MacBook retina a1534 that I just repaired the c-port and replaced some ribbons and the touchpad. Everything is working fine, except the internal speakers. I can plug in headphones and get audio, just nothing through the internal speakers. Internal speakers do show up as an output device. I’ve tried the most common solutions:
1) NVRAM and SCM resets, 2) Created new user, 3) Reseated audio board ribbon cable.
My question is could a damaged audio board and/or ribbon cable affect the internal speakers, even though the headphone output is working properly? Thanks in advance for any insight on this odd issue
The fact you are getting sound via the headphone jack removes everything but the audio board its self! Let me explain…
The action of plugging in your headphone plug into the jack causes two switches within it to alter their state as you can see here
So what’s happing is the closed circuit which sends the signal to the speakers is not happening. Check your headphone plugs as you may be using one that cause the damage or its just dirty. More often I find I need to replace it MacBook 12" Retina (Early 2015-2017) Audio Board
crwdns2886500:0Replace the circuit assembly that supports the audio in/out port.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$39.99
i am having a very similar issue.. i just replaced the battery and now i have an audio problem.. speakers dont show up at all in hardaware :/
@zakkholder - Check your cable connections to the audio board, you may need a new MacBook 12" Retina (Early 2015-2017) Audio Board Flex Cable. The audio board holds the DAC chip so loosing connection to it from the logic board is a common issue. To be sure see if the headphone jack works if it does then the issue is within the jack unit like above.
Doug Hamilton crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 164
