Repair guides and disassembly information for the MacBook Pro 16'' released in November of 2019. Model A2141, EMC 3347.
crwdns2934591:0210crwdne2934591:0 crwdns2934593:0crwdne2934593:0
External USB Camera keeps turning on and off (see video)
I have a Sony camera connected via the elgato camlink stick. Everything worked fine, until I plugged in a multi-usb adapter. Then this strange behaviour you can see in the video occured, forever :(
Here are some logs
  • Turned off and on
  • Tried another Macbook (same behaviour there, very strange)
  • I reset the SMC and PRam.
Update (03/24/2021)
Hi guys, thanks for your support!
I do not know why, but it works.
I changed the adapter and everything works fine. That is weird, because everything worked fine with the adapter that I exchanged. Thanks for your thoughts @logixal, inspired me to adjust a cable.
I am not sure if this will help anyone out there, as my setup is quite specific.
But what I can tell (if someone stumbles upon these error messages) that this must be some software related issue. I am not sure, if the third party usb hardware that I have plugged in updated my usb drivers. Being uncertain, my next step would have been @danj s advice, speak to elgato / apple and sending them some of my logs (spotlight -> console).
What happens when you directly connect the Elgato Camlink stick to your system? Or another system which has a USB-A port.
@danj Hi Dan, everything works fine on my Windows (direct USB-A connection). But I am pretty sure it is not an issue with the adapter (worked fine before). I think it is a problem with my Macbook. I uploaded a screenshot with some logs (console).
glad you got it working!
If its a high def camera you might need its own hub to operate. the cam link draws power from the USB correct? There’s no other power source for it?
I had a problem with having my HD camera plugged in and my Elgato on the same hub. It would cycle my camera on and off. You may need to get a USB Power booster to run both on the same USB outlet.
@Alex Friedl - The log entries imply a OS level issue not hardware.
You'll likely need to speak with Elgato on their Camlink stick drivers and you may need to also talk directly with Apple.
I would also try using a USB-C to USB-A converter or a real Apple USB-A dongle to see if the hub you are using is a factor.
Alex Friedl crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 956
