The Game Boy released on April 21, 1989 in Japan, followed by North America on July 31, 1989, and lastly in Europe on September 28, 1990. It is characterized by a large grey casing and model number DMG-01.
How do I fix my battery spring corrosion
I have an original Gameboy but the battery springs are corroded.
If you want to clean the corroded spring, you could dip a cotton swab in isopropyl and rub it on the spring, it could help a bit. But I’d recommend buying new battery terminals, depending on which contact is corroded you’ll have to do a little bit of desoldering, as there are 2 contacts in the upper part of the battery case which are soldered to the gameboy’s circuit. The ones circled in the image below to be more precise. The squared ones are just terminals which can be easily popped out of the case and replaced, you can find them easily on the internet.
So on the Internet I found the terminal and can only buy 20 and shipping $8 bucks. I won't do it?
Also alcohol does nothing. Maybe dip in vinegar for 15 min then make baking soda/Water paste and a toothbrush . Then use a knife and Emory cloth on metal..
It very much depends on how bad the corrosion is. Light corrosion could possibly be fixed with IPA and a toothbrush, for something more serious I'd let it sit submerged in vinegar for a few hours. The last option is to use sandpaper and sand off the zinc coating to expose the copper underneath
Dominik Havlicek crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 46
crwdns2936753:030crwdne2936753:0 205
crwdns2942667:0crwdne2942667:0 14,419
