The GMT800 Silverado/Sierra 1500 and 2500 (non Heavy Duty) (light pickup trucks) were released in 1998 as 1999 models.
Gas Guage wont Work on instrument panel
I have a 2000 gmc Sierra 2500 6.0 and I'm having problems with battery gauge flickering and my gas guage will work and then just stopped working altogether and now it has gotten to where it won't work at all, do you have any advice or know what I should do because I've already checked fuses and ground wires and that doesn't seem to be the problem
Hi,
With the flickering battery light problem check that the alternator/voltage regulator, voltage output is OK.
When you do this ensure that the transmission is in park (AT) or neutral (MT) and that the emergency brake (aka hand brake) is firmly applied.
Then with the engine running open the bonnet (hood?) and connect a voltmeter across to the vehicle battery terminals. Set the voltmeter to measure 20V DC and connect the red meter lead to the +ve battery terminal and the black meter lead to the -ve battery terminal.
The meter should show approx. 13.8V -14.5V across the battery terminals.
If the meter is hovering below or about 13.8V it means that the battery is not being charged due to insufficient voltage from the alternator or that the voltage regulator which is built into the alternator (I think) is faulty. That is maybe why the battery light in the dash is flickering.
Be safety aware when doing this as the engine is running.
You could also check that the fan belt has the correct tension and is not slipping on the alternator pulley which may also be causing a faulty output. Do this with the engine off of course ;-)
If you don’t have a DMM (digital multimeter) to test the alternator output most car battery replacement dealers will usually check this for you.
The fuel gauge problem may be due to a faulty sender unit in the fuel tank or a loose connection somewhere between the sender unit and the gauge.
Aaron Parrott crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 205
