Battery charging slows down after passing 90%
Hi! I recently finished a battery replacement on my Retina MacBook 2015 and it went very smoothly. I followed all the steps in the guide and made sure I was careful when performing the repair. I hooked up the Mac to low voltage power after the repair as well, so I’m pretty sure I avoided any potential logic board damage there. What I’m noticing now is that the battery charges as expected from 0% up to about 90%, and then begins charging very slowly. According to coconutBattery, it’s charging with 2-4 watts after 90%, which seems really low to me. It seems unlikely that there is logic board damage because it charges correctly for the majority of the charge cycle, but I’m not sure. Is this normal behavior for battery charging or should I be concerned? Thanks in advance.
Lets look at this a bit differently…
Did you watch the docking of the SpaceX Dragon space ships to the ISS? SpaceX CRS-21 Dragon docking
Note how it gets close to the station and then comes to a stop at a set distance and then it moves forward as a much slower rate and then when its within a few meters is really gets slow!
Batteries are similar! They can charge at a high rate when discharged more than a third but as the battery gets full the charge rate is dropped and then its at a trickle!
This is all normal!
Cameron Schmottlach crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 116
