Speed only works on highest setting on the dial
Hi my Kenwood mixer will only work at the fasted setting on the dial
Update (12/18/2020)
- On the fastest setting on the dial
@freddifrog this is most likely caused by a failed spark suppression capacitor for the governor. IF it fails your mixer will only work at full speed. Check for it under the cover on the bottom of the motor. You’d be looking for a small, round, aluminum can looking part. Post some images of what you find so we can assist you further with that.
Here is Untitled the service manual to help you with your disassembly etc.
there are two aluminum can looking parts but how do I know which one works and how can I replace it and where can I get the part?
There's sure to be a label on it. Post a photo here, we will help. Replace both, they're cheap. You can usually get them through an mail order company for electronics.
I had the problem on kcc9060. I changed the dial element (so the triac) and i solved the problem.
The problem returned its not the dial maybe the motore rotation sensor
crwdns2942667:0crwdne2942667:0 704
crwdns2944067:09crwdne2944067:0
Can't find an option to add a photo
crwdns2934271:0crwdnd2934271:0 P Greenwood crwdne2934271:0
@freddifrog here is the guide for it. Adding images to an existing question You'll have to edit your QUESTION and add those images to it.
crwdns2934271:0crwdnd2934271:0 oldturkey03 crwdne2934271:0
Thanks. Just having a look.at it now
Apparently I need a part
I need a part BTA208-600B
crwdns2934275:04crwdne2934275:0
