Repair information and guides for the updated version of the 2015 Retina MacBook that was released in early 2016. Model A1534 / EMC 2991
Changed LCD cable still got white screen
I had a white screen issue with my MacBook replaced the LCD cable. I still got white screen problem after replacing the LCD cable - MacBook do work on a external monitor. Anyone have idea what to do about it? Should I do something actively to activate the new cable for some reason it don’t work?
Given the fact the external display is working, and replacing the cable didn’t alter anything tells us the internal display logic its self is bad. Just like the MacBook Pro Apple moved the T-CON logic to sit within the main case vs the display lid. This puts it at risk either overheating or the massive number of cables now required
Here’s the guide to replace it Retina MacBook 2016 Display Assembly Replacement
Thank you for reply sounds like it’s very possible you are right. What confuses me a bit before replacing the cable at times when the screen where in a certain angle it worked. Eventually it been hard to find get it to work not having a white screen so I thought it might be faulty LCD cable so it lost connection somehow.
You had the right idea! Just couldn't replace the damaged cable which is one of the two cables from the T-CON to the LCD panel. The other two is the backlight and the FaceTime camera I've circled.
Jim crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 110
