Well… Yes and no!
The LCD panel are the same so if you switch out the LCD then you’ll be fine! Replacing the full assembly gets risky!
Apple switched out the LVDS cable connector from on version to another which are electrically the same but they are physically different! The 2011 LVDS logic board and cable connector is wider than the 2012 versions!
When I upgrade the 2011 logic boards to the better 2012 boards I need to grind the tang so it fits into the socket (very little needs to be removed). But the little difference going the other way can get you into trouble!
Here the narrow cable end is floating a in the larger socket. So it can shift a bit shorting out the connections! As we can’t make the tang wider the risk is there.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
