The Latitude E7440 is an ultrabook by Dell released in November 2013, identified by model number 730-6964, with a fully usable touchscreen display. It is a high end business laptop built to be portable and sleek yet sturdy.
crwdns2934591:014crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Removing the BIOS asset tag from a used Dell?
I know this may be a bit exotic for the iFixit community and that's fine. I purchased 2 E7440 i7 FHD Touch systems as a lot for almost nothing compared to what they get complete, so I took a chance and both were easily repaired - even if it took a new drive (pulled), spare RAM and 2 LCDs (1 with TAB issues, other from a junk system that was too far gone - fried inductor and dead shorted motherboard). I’ve blurred the tags to protect the previous company if anyone knows.
PART 1: I noticed this because I needed to confirm the tag on the bottom matched for the ownership transfer (otherwise I remove the sticker, and replace or leave blank) so I decided to make sure it's not hiding an asset tag while I was there after it passed the tester hard drive check (shows in BIOS).
PART 2: When I checked for anything I want to change in the BIOS before I install Windows, I did go though the BIOS to see if I need/want to adjust anything and they have a BIOS asset tag. The issue with Dell is you can’t clear this out in the BIOS once set (although it can be set in BIOS) and it persists. I did some research and I think I know what tools I need to use, but I’m not 100% clear. It looks like a job for CCTK (Dell Command|Configure) on the E7440, since it’s such a new machine that may not work with the legacy Platform Tag Utility.
Is there any instructions on how to do it I should be aware of, and which one will clear it out? Normally I’d know this, but you do not run into this every day.
Hi Nick, Have you tried this Dell utility?
https://www.dell.com/support/home/en-nz/...
I got this from:
https://www.dell.com/community/Laptops-G...
Let us know how it goes.
@aactech Why would someone leave an asset tag in the BIOS like this? If you know how to add it, you can remove it. Granted I didn't know because this is a first time issue for me to the extent I needed some clues, though.
I mean sure they're old but these have the i7 CPU - they're worth rebuilding if you're equipped.
They were sold as no boot systems though.
@aactech Didn't work - permission denied when I fed it one of the tags from the E7440s :(.
Hi @nick
Did a bit of searching and came across this which may be of some use
@jayeff Going to try that, but I need to update the BIOS on both - they're both really out of date. I had to wait since Dell REALLY do not like to allow a BIOS update without a battery. The other will need to be brought up to A27 as well but I can do that. The one I just did was sold to me with A08(!!!). Other is at A11 so it may be fine as-is for the asset tag removal, but it's too far out to not do it.
One is done, but the other is still a work in progress. The touchscreen is a gimmick, but it at least guarantees 1080p.
YEP - it's no longer there so that did it. Didn't need to remove it, but no point in keeping it on a system that doesn't need it. BTW the price was super agreeable for the risk of a dead board vs. getting these running. The boards for the i7-4600U version I have are especially expensive to the point if the boards were toast, I'd just use them for parts and buy another machine. i5s aren't as bad, but I wouldn't mess with a board in a i5 version.
I just did the other one lol. Had to upgrade the BIOS from A11>A24, but I only did it now because of a line issue on the LCD with the other one.
Probably would have worked on A11, but it complained on A08 on the other one.
Nick crwdns2934231:0crwdne2934231:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 68
crwdns2936753:030crwdne2936753:0 353
crwdns2942667:0crwdne2942667:0 18,574
