Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
crwdns2934591:0204crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Drive boots multiple times when internal but once from USB
Hello,
I have a problem with my 2011 Mac Mini, High Sierra.
When I use my drive as an internal drive, my Mac needs to reboot multiple times (1-3 mostly), but when I use the same drive and use it as an external via USB it boots just once.
Multiple boot-ups only happen from a cold boot up. Once it goes to the login screen and I log in, turn in off, and then on again, it boot ups normally.
I have reset pram, SMC, and all that stuff.
I reinstalled my os multiple times now. Now I will try to install it fresh from the bootable drive.
Also, I have swapped the flex cable from the original to a replacement one from aliexpress. I do not have the original one anymore, so I cannot test if it is the problem.
I would really appreciate some help with this matter as I want to sell it but I do not want it to fail a new buyer.
Cheers!
You likely have a worn or damaged cable. Follow this guide Mac mini Mid 2011 Hard Drive Cable Replacement to get the drive out of the lower bay. If you have a dual drive and the boot drive is in the upper bay follow this guide Installing Mac mini Mid 2011 Dual Hard Drive Kit
crwdns2886500:0Mac mini Mid 2011 Hard Drive Cablecrwdne2886500:0
crwdns2930805:0crwdne2930805:0
crwdns2934079:0crwdne2934079:0
crwdns2937801:0crwdne2937801:0
crwdns2886500:0Mac mini Mid 2011 Dual Hard Drive Kitcrwdne2886500:0
2 - 4 hours
Are these legit? They're quite pricey. I have tried another flex cable (alliexpress one) and the problem continued.
I think I will try to get a lower specced Mac mini or broken one for parts and try to get the cable this way.
@sebastian.kisiel - Demand and availability dictates things ;-{ Getting these cables is getting hard.
sebastian.kisiel crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 36
