Released September 21, 2018. Models A1920, A2097, A2098, A2100. Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray. (Pronounced "iPhone 10 S.")
iPhone XS laging and restarting after 3mn
Hello,
I did a back glass replacement and after reassembling the phone. It is laging. I tried to do some troubleshooting
1- when i disconnect the back and front camera the phone works well with no lag
2- when i connect only the back camera the phone lags ( the camera is work but not a the first attempt )
3- when i connect only the front camera the phone lags ( and face id says “face not visible” )
4- when i connected both cameras, phone lags ( both cameras are working, but the flash doesnt )
5- For the restarting issue i think i damaged the charging port while removing the back glass. I read that in another forum
Please help. I dont know what else to do
Back Glass or Whole Housing replacements can suffer from the same issues, mainly damaged flexes or connectors. If the phone works fine without the cameras, then closely examine the camera flexes and connectors (and the equivalent connectors on the logic board.
Look for tears in the flexes, even the tiniest ones. Sometimes the connector pins get damaged or some surrounding components can be fully or partially dislodged. All of this inspection may require some magnification.
EDIT 2020-10-26
Take a closer at this flex, based on your picture below (https://ibb.co/g9qRMTj).
I doublechecked the connectors and the flexs but i haven´t seen any damages. These are some macroshoots i took, maybe there can be helpful.
What about the restart after 3minutes ? Is It the Charging port which needs to be replaced ?
https://ibb.co/G2yvSwF
https://ibb.co/7kYG0Q4
https://ibb.co/D8gF0FP
https://ibb.co/F3nXKRQ
https://ibb.co/QJcmmXK
https://ibb.co/VWcXHDD
https://ibb.co/pR8S4CS
https://ibb.co/cCbscS9
https://ibb.co/GPqB8m9
https://ibb.co/wzyrhQ7
https://ibb.co/Kh1Bntb
https://ibb.co/H4vmPSY
https://ibb.co/9HXD2gs
I double checked the flex but it is not damaged. i took a better picture
https://ibb.co/N1WHX5W
Hello Michel,
While the phone is on connect it to your pc run CoconutBattery app: https://www.coconut-flavour.com/coconutb...
If the design capacity shows value around 100mAh (normal value would be the thousands range ~2000-2658mAh)it would suggest you damaged either the battery connector or a tiny component around the connector. If that’s the case you would need a professional to fix it. It would help if you cold post pictures of the battery connector in question.
Heloo Roman,
thank for your response. I don´t have a Mac but a Windows PC. I used 3UTools to check the Ah. It shows 2642mAh as designed capacity.
These are some pictures.
https://ibb.co/yVmM1Nf
https://ibb.co/m0x4VDt
https://ibb.co/TYgWYBq
https://ibb.co/yYcyFq2
Did you figured the issue? Because I have the exact same issue.
I replaced the charging flex cable with new OEM and still the issue is there.
Michel Ngne crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 286
