Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
crwdns2934591:0745crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Why is my laptop not turning on?
Hello , lately my sister told me that she ˝broke˝ my MacBook Pro
It was working good , and when i plug my charger in it goes from Green to Orange like it should when its Charging ……… but when i press the power on button nothing happens ?
I opened to check for dust , but there was little dust (mostly none) and i closed it and putted it away.
Any suggestions ?
Where do you live? Nearest city lets see if we can aim you to a local shop who can help you.
@danj i live in Serbia ( Pozarevac ) but i know one store that can help but its too expensive 200$ for fix (the dude is asking ) but i got that laptop for 50$ so it doesnt make sense for me to go in shop to fix
Okay, not that experienced with the 13in unibody but I’ll give it a shot.
  1. Try the usual PRAM and SMC reset, I’d especially try resetting the SMC
  2. Maybe the display connector has gotten loose? It’s highly unlikely but it doesn’t hurt to check
  3. Try booting with the “no battery installed” option. Since you’ve opened up the laptop, you should be able to just disconnect the battery, but try doing the following with the battery first.
    • Unplug everything
    • Hold the power button for at least 10 seconds, don’t release
    • Keep holding the power button, plug in the charger, then hold the power button for another 10 seconds
    • Release the power button, then press the power again like you normally would boot
  4. I’ve had to do this for macs without a battery, I think it will also ramp the fans up to 100%, but see if there is a screen.
Dead systems are hard too diagnose. It could be quite a few things which makes tough to fix without following a good diagnostic process.
Wants hard is without having access to spares to slide in and out like a battery, DC-In board & logic board for starters. You then need to test each part discreetly. Referencing schematics and board views of the logic board and using a DVM to measure things.
As you hadn’t spent that much on the system att his point, can you find a second of the same series?
lazic.lazar.2005 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 55
