Released September 20, Apple's largest and most expensive 2019 smartphone features a 6.5" OLED display, a triple-lens camera system, and greatly improved battery life. Successor to the iPhone XS Max.
iPhone freezing after screen replacement
I replaced the Digitizer on an iPhone 11 Pro Max and it seemed to work fine during testing. The customer called a couple hours later saying the phone is freezing. It works fine after a hard reset but only for about an hour then freezes up again. Any suggestions? Could it be the aftermarket LCD I installed?
It could be a bad screen or perhaps something went wrong during the repair. Obviously, you should take a closer look to see if any of the flexes are damaged or if any components were damaged or dislodged near the relevant connectors.
As a repair shop, you probably have other screens so I would try one of those first. If you still have the customers original screen and it is functional, try that one too.
Kenny G crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,764
