Flickering display - Display ribbon loose - LG display used
Bought the computer with a loose screen hinge, stagelight and a flickering display (usually in one side). Used to push the screen in to make it work. Found out the back of the screen was not glued. So I was able to open and see what I was pressing on. I have an LG display, not sure if it’s a replacement. Anyway, it’s a ribbon that seems to be loose (last pic). Is there a way the seat the ribbon permanently without opening too much of the Macbbok? Also is the board that is under the black tape installed correctly? It is screwed above the clips but I think it may go underneath it. I have another OEM screen to swap as well as an option.
Issue
Location of ribbon - Board/connector shown screwed in front of metal clip
Loose Ribbon
