The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
crwdns2934591:01185crwdne2934591:0 crwdns2934593:0crwdne2934593:0
What is this chip by the lvds connector a1502 early 2015 MacBook Pro.
I bought this MacBook Pro 13” early 2015 with a screen that looks like a bad TV channel with interference. Could this chip by the lvds connector be the cause? It’s damaged. I have another late 2013 a1502 with a similar chip. Is that compatible?
Update (09/29/2020)
this is what the screen looks like. The seller said it just stopped working. When I opened the case I noticed the damaged chip.
What does an external monitor show you?
This is tricky! If the video signal is messed up on the HDMI port and the Thunderbolt/DP ports (check both) then the issue is within the logic board.
If its clean on the external display on all the ports the internal displays T-CON logic is damaged which is part of the display assembly.
The output to the HDMI was pretty much blank. Probably not worth fixing this one. The kid said it worked fine hooked up with the HDMI. I thought it might have been as simple as a lvds cable. Buying broken laptops is always a risk.
This is an inductor coil L2920
While the ferrite element is damaged I don’t see this is the cause of your display issues. Can you post a few pics so we can see what you are seeing.
Thanks Dan. I wish there were classes out here on board repair. I wanted to take the class Jessa had at iPad rehab in New York but Covid hit, had to put off my plans to attend.
Sorry it didn't work out. Don't forget to score the answer and accept it, thanks!
Brian crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 163
