Repair information and guides for the updated version of the 2015 Retina MacBook that was released in early 2016. Model A1534 / EMC 2991
Won’t turn on after SMC reset
Hello, I have a 16 Macbook that just went dead. Tried to reset SMC after it wouldnt charge and not it wont turn on. Any fixes?
If there isn’t any fix, is there any way to recover a few documents on there? This one isnt saved onto my iCloud unfortunately. I’m assuming you cant just mount the hard drive elsewhere since it’s soldered in.
Any help very greatly appreciated.
Given its age its possible your battery has just died. At this point you’ll need to find your way to someone with the deeper skills and access to a spare battery to test your system out.
At worse give your system enough life to allow you to backup your last few files to your iCloud account before giving your system its last rites if you want to move to a newer system.
Update: I guess I wasn't clear.
You would need a charged battery to offset the inability of the USB-C port from charging for what ever reason. Then you could quickly backup your data to the iCloud before the spare battery died.
To do it your self you would need this: MacBook 12" Retina (Early 2016-2017) Battery and here's the process Retina MacBook 2016 Battery Replacement
Frankly, I would find someone who has the battery who can quickly connect it long enough test your system and to do your backup Vs buying the battery.
Since you had issues with the USB-C port you might be lucky enough to just replace it! MacBook 12" Retina (Early 2016-2017) USB-C Port Assembly
crwdns2886500:0Replace a damaged or corroded USB-C port and the flex cable that attaches it to the logic board in an early 2016 or 2017 model 12" Retina MacBook.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$99.99
crwdns2886500:0Replace a 4800 mAh battery compatible with MacBook 12" Retina (Early 2016-2017). 36.2 Watt Hours (Wh), 7.55 Volts (V).crwdne2886500:0
$109.99
Hi thanks for the answer. I was having some USB C problems before that, when the USB just completely died on me. Might be a logic board issue. Worst case scenario, is there any way I can get the data back? Thank you
Pol crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 62
