Is there a way to test charge port flex
Is there any way to test the charge port flex ? When plug in the test meter shows .47 and stays there . How can I determine if the charge port flex is bad
Connect it to computer, does it register? There are Tristar/port testers you can plug in but first is it in DFU Mode? Will it go into DFU Mode/recovery mode if not and connect. If it is or can connect, will it restore or update without error? You can open it and test with multimeter as well…
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 108
When you plug the cord in it sounds and shows charging then it goes away
crwdns2934271:0crwdnd2934271:0 Phil Pusateri crwdne2934271:0
Thanks it did not respond when I plugged it into the computer so the charge port flex will need to be changed—Thxs
