Released October 26, 2018. Models A1984, A2105, A2106, A2108. Available as GSM or CDMA / eSIM, nano-SIM or dual-SIM / 64, 128, or 256 GB / Black, White, Blue, Yellow, Coral, or Red. (Pronounced "iPhone 10 R.")
iPhone xr no power after charging overnight
woke up with a dead phone. the phone was plugged in to the charger overnight and when i woke up all i had was a black screen. tried force restarting the phone. tried plugging the phone in to a computer. tried multiple known working chargers. due to the pandemic and my desperation i checked in to a local repair shop they opened the phone and unplugged the battery from the main board and checked diodes and said a bigger repair shop needs to take a look. they didnt have spare battery to check on my phone. if i bought a new battery what are the chances of seeing my phone back to life?
Did you use an official apple cable or a cheap one?
@uk_nick
official cable and charger
I would try a new battery first. It has to have a battery hooked up to turn on or have a power source hooked up to the battery connection. It will not turn on with the charging cord. It's a possibility that the battery shorted out. So buy a new battery from ifixit and try that.
Ok, I'll try that. Thank you. If say the battery shorted out, would the amp meter read zero while plugged in?
What is the voltage on the battery?
If the battery has zero charge it could have a bad tristar ic which controls the charging and data transfer. It is usually caused by using a aftermarket charging cable that is not MFI certified which can cause voltage spikes and damage the tristar ic especially if used in a car to charge the phone. A repair shop can test the tristar and it only takes a minute and most shops won't charge for it
No voltage on the battery. Thanks for all the input.
Carlito Calub crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 399
