iMac no image on internal, only with external display
Hi,
My Mac computer doesn't show image, only when I connect an external screen.
Only when you get to the desk you can see a slight illumination (like a light beam) I have tried to change the power supply, inverter, video card, full LCD screen (including LCD cable) and finally change the motherboard.
I need help or it is a motherboard problem and this second hand also has the same failure or the aluminum of the computer causes failures (hahaha)
Please I need help! Thank you very much in advance
Update (08/05/2020)
Hi,
He reviewed this but it seems fine. It is a motherboard bought on eBay and with my previous motherboard did the same thing happen do you think this part was damaged? It is possible .. I will return the motherboard and buy another one again.
From an external monitor, if I try to adjust the brightness in preferences, I see how the screen lights up a lot and turns off with the room in the dark.
If in a dark room you see the screen has a slight glow that tells us the backlight is working properly.
Most likely your logic boards LVDS connector had become damaged. This often happens when you tug on the cable when you try to get the display disconnected as the cables length is short and easy to mess you up.
i update my post sorry i can't answer u
quique quique crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 132
