I have a De’Longhi all in one machine model # Bco 330T
The coffee maker portion of the machine is not heating up, I don’t hear the coil heating the water. The espresso maker portion works fine is this repairable?
After doing some research, apparently this is a common issue with this brand. So, there is a central heating plate that heats the water for the espresso side and brewing side. The thermostat on the plate goes out and thermostat fuse gets blown. I will link a YouTube repair video below that explains this. Even though the model is a little bit different, it will be the same concept. I hope this helps. DeLonghi BCO430 Coffee Maker *WON'T BREW* *FIXED*
I apologize, the video has a model with a separate plate for the brewing side. This is why I felt it would be the most helpful for you.
crwdns2942667:0crwdne2942667:0 2,872
@pchris330 - If you need to make corrections go to the Options tab to make the edit or if you need to add information you can also create a new Answer entry when you save it will ask you if you want to post as an update.
crwdns2934271:0crwdnd2934271:0 Dan crwdne2934271:0
I have the same problem. It appears that the clock/coffee maker is a separate circuit or board than the espresso half. This morning the clock and coffee maker portion won't operate. (I should add that the machine has lasted for 6 years with daily+ use so it is long past any warranty or extended warranty.) I see there is a repair video link with a similar model in the answer. If I can figure this out I will author a repair guide for this model, as I don't see one yet.
crwdns2934271:0crwdnd2934271:0 L- B crwdne2934271:0
